01-27-2011 11:24 AM
Is is possible to develop an application which is
that installs and run under 64 bit Windows ?
If so, what are the steps involved ?
Morten
01-28-2011
03:27 AM
- last edited on
07-01-2024
01:36 PM
by
Content Cleaner
Hi Morten,
I presume what you are asking if it's possible to run an 32-bit application on an 64-bit Windows 7 platform. This is possible because a subsystem called Windows-on-Windows (WOW64) included in the operating system that allows 32-bit applications to run on the 64-bit environment.
The steps needed will be the same as Develop & Deploy applications on 32-bit only enviroments.
Hope this is the answer you are looking for.
Thanks!
02-02-2011 12:46 AM
Hi Morten,
Check out the "64-bit Support in Measurement Studio .NET Assemblies" help topic in Measurement Studio help, it talks quite a lot on 64bit support in Measurement Studio.
To launch the help go to Measurement Studio main menu in Visual Studio IDE and click on the NI Measurement Studio Help menu item.
Vijet Patankar
Nataional Instruments.
