‎12-21-2010 09:41 AM
Is there a 488.2 NET lib equivalent for the old gpib-32.obj SendList function?
I need to send the same command to selected multiple devices at the same time. Not all of the devices on the bus.
I found the Board.SendCommands function, but there's no way to send an address list.
Curt
‎12-22-2010 04:54 PM
Hi Curt,
SendList in the C API is replaced by Write in .NET. You use the Write command to send a command to an AddressCollection. You use an Add function to add new 'Address' data types to the collection.
This information can be found in the .NET help for 488.2. Go to Start»All Programs»National Instruments»NI-488.2»488.2 .NET Framework help.
This should do what you want.
Take care!
‎01-04-2011 01:48 PM
