Measure
1D array saved
Hello Smiley Happy
I have a problem when i want saved all data from a Array dinamic after than the VI finish. I want save it in format excel for columns for each array dinamic existing. In "Example" see the code and in "Example front panel" result of array dinamic.
Any idea?
Thank!!
Anto
(4,908 Views)
Hello Anto,
Just to make sure I have it straight, you are trying to save multiple 1D arrays as columns in an Excel file, correct? This thread may help you get started: http://forums.ni.com/t5/LabVIEW/how-to-save-dynamic-data-to-a-spreadsheet-with-only-two-columns/td-p...
Let us know if that helps!
GiantDeathRobot
William R.
(4,880 Views)
