Machine Vision
wrong lake detection
Since you appear to be completely "out of track", I'll try to point you in a better direction. The starting point is your statement that a "lake" is a specific pigment spot. Accordingly your question reduces to a problem of color recognition.
What I would do is :
1/ Find the color spectrum of the whole iris, excluding the white surrounding region and the black central pupil. For that you should first create programmatically the corresponding annular ROI (ROI-1), and then use  IMAQ color learn.vi.
2/ Define a small circular ROI (ROI-2) that will be used as a probe. Chose a circle diameter corresponding to the size of the lakes to be spoted.
3/ Move this probe in a loop over the entire ROI-1 and see, for each position if there is a color matching, using  IMAQ ColorMatch.vi. You'll have to define the required minimum match score by successive trials until you reach a satisfactory result. I would use 600 as starting value.
That way, variations of the ROI-2 color relatively to the average iris color would be detected, giving you the position of the "lakes".
This, of course, is *much* different from your proposal, and you'll have a significant amount of work to do, that can't be achieved in NI Vision assistant, altought some prototyping can be done with rectangular ROIs. Well, image analysis is not for the faint-of-heart, and the sooner you'll realize that, the better ! 😉
And again, if you where able to better define what a lake is, and show somebody how to locate the lakes, other strategies, may be simpler to implement, could be defined. Yours is truely a dead end...
Message Edité par chilly charly le 10-31-2007 03:36 AM
Chilly Charly    (aka CC)
Message 11 of 14
(1,384 Views)
Finaly after several tests i managed to finish my NI vision assistant and i am working on labview design..I made a simple design but i still got some problems, can anyone plz explain me what do i have wrong in my design so i will change it..The problems are two.When i run the labview and load the two color images when i click or move the screen it will apear the last image i load and i will have two same images..The second is the compare part it doesnt work and it shows nothing...
Thnx a lot
Message 12 of 14
(1,343 Views)
Sorry i saqw ur post after i posted my.I did the colored matching in NI vision assistant with starting value 600 and i have positive results.Thnx for ur interest about my project but i was really lost in the beggining and my posts wasnt so clear.The thing  is  that in IMAG i have the result si want but i still have some problems in labview as i report in my prvious post..
THNX FOR UR INTERESTSmiley Happy
Message 13 of 14
(1,342 Views)
Well...
This is the kind of work that deeply depress me.
Being a professor myself, I would evaluate this work with an E, because, as I already explained and as you perfectly know, your program can't work.
You have been cheating all the way !
Clearly, you'll be in trouble if you think your professors are that stupid and incompetent !
No need to come back here asking for help if you don't even try to produce something with a significant thinking input !
Message Edité par chilly charly le 11-07-2007 12:33 AM
Message 14 of 14
(1,340 Views)
