Machine Vision
vision acquisition timeout error
In one of my frames, I inserted a case structure. And every case contains a vision assistant VI. Is it advisable?
And if I find my system having a low frame per second, what can I do to lessen it?
Thank you sir for being eager on responding in my questions. Good day!
Message 11 of 12
(2,688 Views)
Putting Vision assistants in different cases should be fine.
Here is a resource which goes over some steps you can try to increase your frame rate.
Have you tried running that example and checking the frame rate there? Is this comparable to your current frame rate?
Paolo F.
Message 12 of 12
(2,679 Views)
