Machine Vision
How to count number of vehicles using image processing tools in LabVIEW
anyone can give me idea that how to do counting of vehicles using image processing tools
Message 1 of 8
(7,903 Views)
if camera is stationary, first take an image of the background. Then subtract each acquired image from the reference image. Limit the region of interest - build a mask of the area, where you want to detect vehicles. Use only the pixels that are under the mask for further processing. You probably would need to do some morphological operations (for example dilate) to make the detection more noise-free...
Maybe you could get more reference images (different time of day) and compare the average intensities of the acquired and the reference image to select the best image for subtraction.
You could then probably just count the numer of objects to get the number of vehicles.
You can perhaps also use optical flow to track the vehicles, but you would need to compute some features for example strong corners for each vehicle (check good features to track, http://docs.opencv.org/modules/imgproc/doc/feature_detection.html). Or you can use the new mean-shift tracking library (Labview 2013).
Hope this helps a bit.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 2 of 8
(7,887 Views)
Can you provide me vi for that morphological operations,
As I am new to this field, I kindly require your guidence,sir?
Message 3 of 8
(7,879 Views)
Sir, Can you give me an idea , How to convert gray scale image to binary image???
Waiting for your reply as soon as possible..Thanks...
Message 4 of 8
(7,877 Views)
regarding your post, I strongly recommend that you first take a look at the included examples:
Help -> Find Examples
Also, take a look at the NI Vision Concepts Manual:
...\National Instruments\Vision\Documentation
You can convert the grayscale to binary by thresholding an image.
K
Message 5 of 8
(7,875 Views)
Sorry, I forgot:
Morphological operations are located in Image Processing toolbox!
K
Message 6 of 8
(7,872 Views)
sir, can u send me vi for counting cars in following image.
Message 7 of 8
(7,868 Views)
sorry, but I cannot do the project for you. This is a bit too complex to just do it in a couple of minutes...
I can suggest that you find papers regarding vehicle detection algorithms/methods and try to implement them yourself step-by-step. This way, you will also learn a lot.
K
Message 8 of 8
(7,866 Views)
