Machine Vision
unable to interface axis ip network camera
May I know if it possible to interface the Axis IP network camera using the LabView IMAQ software. I can't find any example solution regarding that, can you giving and solution for me. Thank you.
Message 1 of 24
(7,616 Views)
Kentchong,
You can find a list of support cameras on our website at:
To communicate with a camera, you must use a camera file.  The camera files developed by our R&D team for cameras on the market can be found at the link above.  If you are using a generic camera, such as an RS170, NTSC, CCIR, or PAL, our IMAQ driver will install a default camera file configuration that should work for these cameras.
Scott Savage
Applications Engineering
Message 2 of 24
(7,594 Views)
For Win32 systems, Axis provide a developers SDK, which you can download from their site and includes the ActiveX modules for acquiring images.
Message 3 of 24
(7,582 Views)
I have a "Grand Wi-FI Camera", I need to visualize the video in a labview panel, do you have any suggest?
P.S. The camera exporte the file .mpeg4 in a ftp server.
Message 4 of 24
(7,535 Views)
Velectro,
Thank you for your post.  Do you have more information on your "Grand Wi-Fi" camera?  It would be helpful to know the manufactuer, if it is an analog or digital camera, and what standards it conforms too.
If you are unable to locate your camera in the above link of supported cameras, it may be possible to create your own camera file using our camera file generator:
This program is a free tool developed by our R&D team to help customers who can not find a camera file for a specific camera.  While this tool is not supported through our applications engineers, it may be possible for you to use this to find a solution for your camera.
Scott Savage
Application Engineering
Message Edited by Savageaggie on 03-15-2006 12:33 PM
Message 5 of 24
(7,521 Views)
Dear Scott,
the camera is a digital IP camera, protocol = Mpeg4, the manufactuer is Grandtec. You can find any detailes here:
http://www.grand.com.tw/en/product_form.asp?lwk_series=51&lwk_product=e-008-2&lwk_page=
I'd like to acquire the video or a sequence of images from the IP wi-fi camera by internet, visualizing in a VI the image.I downloaded your "File camera generetor" but it isn't supported and I don't know if it may be useful.
But before I must resolve an other problem, I do not succeed to make to transfer by ftp the mpeg4 file on server ftp.
My ftp server have this url: ftp://192.168.0.7 without password.
I set the ftp service of the IP cam in this way:
        Ftp Service
Enable: Enable Disable
Server URL:
User:
Password:
Remote Path:
Have you any suggest?
Tanks a lot
Message Edited by velectro on 03-16-2006 03:34 AM
Message 6 of 24
(7,516 Views)
Velectro,
Thanks for the additional information.  Currently NI dirvers do not support IP cameras of this type.  These are similar to GigE cameras.  We do plan to release a driver designed to work with these cameras in the near future, but a release date has not been set.  For more information about these drivers, please see the following discussion forum post:
Scott Savage
www.ni.com/support
Message Edited by Savageaggie on 03-16-2006 04:52 PM
Message Edited by Savageaggie on 03-16-2006 04:53 PM
Message 7 of 24
(7,500 Views)
Is there already an update about this post?
I need to capture a livestream from my IP camera in LabVIEW anyone knows how to do this?
thanks in advance
Message 8 of 24
(7,408 Views)
Hi Scott,
I am also using a webcamera from Grandtec. The link is http://www.grandtec.com/webcam.htm.
I want to perform image capture on LABVIEW for this web camera. I tried the LabVIEW Webcam Library functions provided by Pete, but somehow I am not able to receive any images on the front panel. I tried running the Webcame Get Digitizer vi to get the driver number, but it only shows WDM at number 0.
Could you suggest me any ideas as I am totally new to this area. Any help is appreciated.
Thank you for your time.
Mozill
Message 9 of 24
(6,815 Views)
If you have NI-VISION then you can try using NI-IMAQ USB.
Let me know if you have any questions.
Have a great day,
GG
Message 10 of 24
(6,799 Views)
