Machine Vision
取消
显示结果
搜索替代
您的意思是:
triggered acquisition with e2v octoplus line camera
I want to do a triggered acquisition from our new e2v octoplus (camera link model). I have it connected to a PCIe1433 board. It needs to be synchronized to a TTL trigger (from a DAC controlling galvo mirrors). That triggering model works for another camera.
With the octoplus I can set the camera to external triggered acquisition mode (using the serial commands), but it doesn't acquire any lines in this mode. When I try this with the CameraFileGenerator I get a message with a timeout. When I try it with NI MAX, I get an error message stating no serial termination character is received.
Do I need to make changes to the .icd file? What changes? (edit: I tried attaching the icd file but it is rejected)
In the end I want to do the acquisition using LabVIEW (the galvo control also runs in LabVIEW).
Aart
0 项奖励
1 条消息(共 4 条)
2,371 次查看
Are you connecting the trigger to the 1433 or to the camera?
With camera link it should be connected to the 1433.
Amit Shachaf
0 项奖励
2 条消息(共 4 条)
2,348 次查看
yes the trigger is provided to the little coaxial connector at the PCIe1433.
0 项奖励
3 条消息(共 4 条)
2,341 次查看
I need to do the exactly same thing. Did you solve the problem? It seems that I need to request .icd file from OctoPlus company.
0 项奖励
4 条消息(共 4 条)
761 次查看
