Machine Vision
time control of two loops
Hi all,
Here I am little bit stuck. I am trying to control the execution of the two loops to display an image, i need to execute the upper loop for example  for 30 seconds, after that it should stop and the lower loop starts execution for 15 seconds and stop. and then the upper loop again execute for 30 seconds and so the process continue in that way.
So please ,if you can share me your hint , that will be appreciated.
Thank you
(5,563 Views)
Accepted by topic author M.Ali
something like this should work.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,551 Views)
That is nice algorithm. It woprks as expected.
thank you for help.
(5,545 Views)
