Machine Vision
shutter time ieee too long
I am using a Hamamatsu IEEE 1394 Camera with a real time controller (PXI 8176). I can get images, but the value for realtive shutter time can only be between 1060 and 1130, but in the handbook of Hamamatsu is written ,that it should be possible from 10 to 2000. In this way, I can almost do no changes in shutter time.
Thanks for solutions
Tim
(3,157 Views)
Which driver version do you have?
Do you use an standard icd file for your cam?
Message Edited by ThSa on 10-21-2005 06:38 AM
(3,151 Views)
Hi again,
everything is ok now, the format for the picture was chosen as a wrong one. When I chose the right one (Format 7), everything worked.
(3,131 Views)
