ā03-08-2010 01:37 AM
ā03-08-2010 03:19 AM
ā03-08-2010 09:08 AM
No
I am unable to open the files. Over the wekend, I was able to match all the objects in
the image using vision assistant. As you guys I was lacking a proper template creation.
I did that and it worked.
I also wanted to ask you about how we can pattern match using line profile as you mentioned
in your last post. I want to do whatever I did right now in color pattern matching. Is there
a way around it.
ā03-09-2010 01:15 AM
ā03-09-2010 01:26 AM
Find the template geo from the previous post. From the pattern matching bounding box you can draw the line profile to get the details. I will show what exactly i meant in my next post
ā03-10-2010 01:13 AM
ā03-10-2010 02:01 AM
Muks
thanks for your help. I havent tried your code yet but I have a working code of my own.
I will try your code 2morrow morning. I think you might have got the IVa mask from ROI from
the vision assitant if I am right. But I fail to understand the concept behind entering those values
in the ROI window. thats the thing I failed to understand.
My other question is can I only extract all the matches in the image. The imaq extract doesnt have
angle with it. It just gives takes the global rectangle. Is there any proper way to extract the matched
template in the image. bcoz i can extract unrotated matched template image right now. I will put a
screen shot of what I did 2morrow.
thanks for your time anyway. If u live in NY I owe u a beer.
ā03-10-2010 03:20 AM
ā04-02-2010 09:22 AM
