Machine Vision
saving changes in circle finder input settings
In Circle finder and Pattern matching
we are using some ROI and input setings ..
i need to save this changes while applcation running itself.
Which method i have to use ..
to save the changes
(4,302 Views)
Accepted by topic author SaranVenkateshS
use xml with event based structure to read and write the selected values.
Xml example (you can write the the circular detection options datastructure directly):
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,288 Views)
hi Klemen,
Thanks a lot for your Solution.
S.
(4,270 Views)
Hi Klemen,
I am having One more Doubt .
is it possible to read paticular variable value in XML (like Config file)
S
(4,267 Views)
