Machine Vision
need to find distance between two circle center
i need to distance between two cirlce centers (x1,y1) (x2,y2)..
Now i am using  formula  distance = x2 - x1. (in this case my image should be Zero Degree)
in this case if my Image is tilted (angle ) .. my calculation will be Wrong ..
I tested with labview vision assitant to find distance measure option .. (it take cares the tilt postion also ).
So i need some method to find the distance . without error
(4,210 Views)
I'm sorry i cannot see the image scenario where you are describing.
-I may suggest you to check IMAQ point Distances if you have vision tool.
-else try euclidean distance between points sqrt(x2-x1)^2+(y2-y1)^2)
-It would be nice if you can add either sample image or code which tried to understand the problem if i'm addressing exact problem.
uday
(4,207 Views)
