Machine Vision
roi line thickness
hello everybody!
does anyone know if it's possible to change the line thickness of a roi? I would like to increase the line thickness to make the roi more visible in a scaled down image (e.g. in my html report).
Thanks for your input.
David
(4,855 Views)
 Hello David,
its not possible at the moment to choose different ROI width. But you are able to read out the ROI parameters and use the "IMAQ Draw" function.
Because its possible to set the width in the IMAQ Draw.
Kind regards,
Elmar
(4,842 Views)
Hello Elmar,
I'm not sure if I get you right. How do set the line width in IMAQ draw???
Regards, David
(4,800 Views)
Hello David,
you can use the Imaq Draw function to draw a rectangular and with the last parameter on the coordinates you are able to select the width.
Kind regards,
Elmar
(4,767 Views)
Hello Elmar,
I still don't understand your IMAQ Draw function. To me it doesn't look as if you could feed an extra parameter to the coordinates array (at last in my application). I've gone a different way now of moving the existing ROI of an image up one pixel, down, left and right and then combining all ROIs.
I've added my example.
Regards, David
(4,674 Views)
