Machine Vision
"Read/Verify Text 1" could not be initialized!
I'm using VBAI to verify text, it's OK to create an inspection but when I re-open this inspection, there's a warning like this ""Read/Verify Text 1" could not be initialized".
Please help me to resolve this issue!
Thanks in advance!
(3,146 Views)
Check that you have a valid path to your Character Set. When you re-open an inspection, VBAI goes through the inspection once to verify that all the steps can be executed. The warning lets you know that a configuration is not correct for one of the steps.
(3,130 Views)
