Machine Vision
"NI-imaqdx devices" folder not showing up in NI-MAX/USB Cameras not recognized
Thanks to Bluecheese.
Your professional answer also solved my problem!
By the way, why do you know so much details? I'm just curious.
Message 11 of 24
(5,697 Views)
BlueCheese is one of the Vision developers at National Instruments.  Note the blue bar above his icon, which indicates NI employees.
Bruce
Bruce Ammons
Ammons Engineering
Message 12 of 24
(5,684 Views)
Thanks for your information.
I'm new in this forum.
Message 13 of 24
(5,668 Views)
Bluecheese I Love you! That fixed my problem!!
BlueCheese escribió:
I'm wondering if this might be a manifestation of a recent issue that cropped up. Can you try renaming "niu3v.dll" in C:\Windows\SysWow64 and then close/re-open MAX?
Eric
Message 14 of 24
(5,150 Views)
Hi.
I have the same problem with imaqdx. I reinstalled the LabVIEW2014-FALL. I want to use USB3 Vision camera
Message 15 of 24
(4,983 Views)
I am trying to get a microscope camera (USB 2.0) to work with LabVIEW. The camera works with other software and has a DirectShow driver (which works with AMCap). In NI-MAX (and LabVIEW) it has never worked so far.
Here what I tried:
  1. Vision Acquisition Software 2011 -> shown under IMAQdx Devices (correct), get a error message when clicked on
  2. Vision Acquisition Software 2014f -> shown under Devices, NO IMAQdx folder, get a error message when clicked on
  3. Vision Acquisition Software 2015f -> same as 2014
The error code is 0x8000FFFF
I attach a screenshot from VAS / MAX 2015.
I have already tried the suggestion from BlueCheese (renaming niu3v.dll) both in system32 and SysWow64 as well as uninstall and reinstall several times. I also reformatted the PC and installed Win 10 (was Win 8.1 before). The system is 64-bit. In a VM I have also tested Win 7, no difference.
Does anyone have another suggestion?
Thanks a lot
Marco
Message 16 of 24
(4,583 Views)
@BlueCheese:
You are really my man. I tried whole last week to figure out what is the problem. I even brought my laptop to the webcam seller to try all their webcams but nothing give me a chance to see Ni-IMAQdx.
By the way, how did you know this solution?
I also to say thank you to the owner of this topic where I can find the solution.
Message 17 of 24
(4,228 Views)
Hello Bluecheese,
    I have been having this exact same issue. I have renamed the niu3v.dll to niu3v(Old).dll like awestek in the SysWow64 and the System32 folder but no luck. No IMAQdx folder shows in NI MAX. I have Windows 7 - 64bit. The cameras I'm using are Ximea USB2.0 ver. 2.0.0.5x64. They work on 3rd party software and are listed in my devices but doesn't show up in NI MAX. Also, I have a trial of the vision module with IMAQ, but I've reinstalled VAS software since starting the trial to install additional software that wasn't there before the module.
   What else can I try?
          Matt
Message 18 of 24
(3,237 Views)
What is the exact model of camera?
What version of VAS do you have installed?  Open up MAX, expand "Software" under "My System" at the top, and look for "NI-IMAQdx".
Message 19 of 24
(3,227 Views)
I am new to the Labview. I could not find the NI IMAQ devices from MAX. I am using a 64 bit OS and Imperx IPX 1M48 L camera with a framegrabber of Teledyne dalsa X64 CL iPro.
I have downloaded the driver and copied it in the specified folder. I also tried renaming niu3v.dll but that didn't work. I am using LabVIEW 2016 with VAS 2016 and MAX 16.0.1
Could you please help me...
Message 20 of 24
(3,153 Views)
