Machine Vision
IMAQdx error DLL could not be found
DLL Not Found.pngI had trouble with this error message. Fortunately I got it resolved. The solution is actually so simple, but I want to bring it up to the NI community, because there seems to be an issue with the uninstallation of IMAQdx driver. Here is what happened to me.
I upgraded the device driver to 2019, but something was wrong that I had to reverse back to the previously installed version. So I uninstalled all the Vision acquisition drivers, IMAQ, IMAQdx, IMAQ IO, all of them from the Package Manager. After installation, there is none left in the Package Manager. I was assuming all drivers files had been deleted, but it turned out not to be the case.
I reinstalled the previous version of Vision Acquisition package, and started MAX. All the cameras showed up, but when I clicked on one of the GigE cameras, it popped a message, saying 'IMAQdx error, DLL could not be found'. Reboot again, still the same message. What the hell ...
By random luck, I checked the 'niimaqdx.dll' file in the System32 and SystemWow64 folders. I was surprised to find that they were still the version of 2019, NOT the version that I reinstalled. That means the uninstallation does not delete the dll file from the Windows system.
I deleted 'niimaqdx.dll' from both folders, and installed the Vision Acquisition again. Everything is working fine.
I am not sure if this is a NI issue or Windows issue. But anyway, I want to put it here so if it happens to you, you can save the time and fix this issue.
(3,312 Views)
I'm not sure what the root cause is offhand. Can you clarify a few details so I can try to reproduce this issue:
What your starting version of NI-IMAQdx before you upgraded to NI-IMAQdx 19.0?
What operating system are you using? (64-bit I assume)
Thanks!
Software Engineer
(3,259 Views)
It is Win10 64bit professional verison
It was a brand new PC, so nothing before installing IMAQdx 19.0. I replaced the old PC and tried to upgrade all the drives the same time.
(3,251 Views)
I tried reproducing the issue with an IMAQdx 19.0 installation on a matching OS system, but I'm seeing niimaqdx.dll removed from the System folders on uninstall. What might have happened was a process was using the niimaqdx.dll binaries during uninstall (ex: a Test Panel in MAX, a built application) so they were not properly removed. In the future, you can recover from this system state by running a 'Repair' through NI Package Manager 19.5 or later.
Software Engineer
(3,198 Views)
Thanks for trying. It is very likely that some other apps were holding the dll file such that it was not removed properly.
so is it possible to implement a procedure in the 'Uninstall' to remind user of this error?
Like, when you are trying to delete a opened Excel file, Windows will prompt you to shut down the Excel file before proceeding to delete.
(3,193 Views)
