Machine Vision
problem about overlay
Why cant overlay text on the image? when program run,the image only display text and black background,in fact i want to overlay the text on the RGB iamge.please help,thanks.
(3,747 Views)
You forget to enclose the "IVA GrayFilter.vi" so I removed it and when running our VI I was receiving an error that says the image is too small to perform the convolute operation, so I also removed the "convolute" and here is the result I got :
just to show you, here is a screen-shot of the code :
Hope this helps
Message Edité par TiTou le 07-26-2007 12:10 PM
Epictetus
Antoine Chalons
(3,735 Views)
thanks TiTou
the IVA GrayFilter.vi was generated by vision assistant,  after i removed convolute, it works ,but not stable.
i add a "IMAQ creat" vi to the extractsinglecolorplan's image Dst ,then the hole programs works fine. Smiley Very Happy
(3,698 Views)
