Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
I'm not sure if I understand the question, but I will give it a try.
It sounds like you want to select one of three shapes and place the ROI on the image. To do this, I would store each ROI as a constant containing the vertices of the polygon. You could probably draw the ROI on the screen and store it. I would then setup three buttons, one for each ROI. When the button is pressed, you set the current ROI equal to the predefined ROI. You can then manipulate the ROI using the mouse to position it over your blob.
Does this answer your question? If not, can you give a little more detail about what problem you are having?
Bruce
Tushar Jambhekar
