Machine Vision
phase unwrapping
Can anyone  explain how to extract phase information from a complex image, plotting it in 3D and unwrap it. I couldn't find any module for phase unwrapping like the unwrap code in matlab
(5,967 Views)
you need to perform FFT on the image and calculate the phase using the imaginary and real part. The phase is calculated as atan2(Im,Re).
Then unwrap the phase (see a similar thread here: http://forums.ni.com/t5/LabVIEW/How-to-unwrap-a-2D-phase-map/td-p/2477554).
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,931 Views)
The link is not working.
(5,920 Views)
sorry, the ".)" at the end are not valid.
K
(5,912 Views)
Thank you Klemen... I will update the progress soon. After some working I used Comlexplane to image for retreiving the phase image. Is the resulting phase information is similar to atan2(Re Im).
(5,890 Views)
