Machine Vision
pcie-1429 trigger delay
i have a PCIe-1429 connected by cameralink with a Basler Camera L104-1k. I use the external SMB connector to triggering the acquisition. It work fine.
I would like to delay the start of the acquisition. To do this i placed an IMAQ Generate Pulse3.vi before the IMAQ Configure Trigger2.vi an set the first block to generate a pulse on the RTSI #0 line. I also set up the second block to read the pulse generated on RTSI #0 line, but the acquisition in not working...
I also tried to configure with MAX the Camera Control Lines Source, setting CC1 Type as RTSI and CC1 number as 0... but without success.
Can you help me?
here is the diagram
regards
(3,481 Views)
Hi martim,
the following link deals with your problem:
How Do I Set a Trigger Delay on a Framegrabber?
Hope this helps.
Fabio
Fabio M.
NI
Principal Engineer
(3,461 Views)
