Machine Vision
no image display in executable
Hi All,
I made an application using labview with image processing and display.
The application runs perfectly on a PC with vision run-time engine installed.
I recently installed the software on a new PC and no image is displaying.
I see that the image grabbing is working fine, but not the display...
On the PC I installed the following drivers :
NI Labview Run-time engine 7.1.1
NI - IMAQdx 3.1.2
NI - IMAQ IO 2.1
NI - IMAQ 4.0
NI Vision 8.5 Run-Time Engine
Any help would be apppreciated
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(3,673 Views)
Same kind of application i just devloped ,i was facing the same problem.
NI-IMAQ Run time and NI-run time vision boyh are needed to display image.
vaibhav
(3,656 Views)
Accepted by DOC-doc
You are right.
But they are already installed...
Sorry but this was a fake problem which has been solved.
Doc-Doc
(3,651 Views)
