Machine Vision
line scan aquistion
Hi!
I have question related to image aquisition with help line scan camera and frame-grabber. My hardware in application is
following: line scan camera, NI PXI-1422 frame grabber (interface between camera and frame-grabber is Camera Link),
encoder, 2 proximity sensors. My questions are:
1. Image acqusition should be only when both sensors are TRUE. How must I configure trigger(s): one trigger for each
sensor's signal or I must make boolean operation for sensor's signals, in order to receive one signal, and connect then this signal to trigger?
2. Where connect signal from encoder in order to this signal be able to trigger camera's acqusition? Need connect to one from trigger's inputs in frame-grabber?
Best regards
Kris
Message 1 of 1
(3,123 Views)
