Machine Vision
learn colur then calculate area
Dear pro,
how can i learn colour, see my attachment that it contains a few colour effect from Label Object in Vis Assist.
I want to do, learn colour for each
Then after that, i would like to calculate area for each. For sure the hand gesture is the biggest are
LAstly, i will do simple math to pick the biggest area object and neglect the rest
help me please
Regards with Salaam
AbangCorp
(3,686 Views)
sorry, i forgot to attach image file
open this link please ... http://shw.fotopages.com/15995414.html
err, i dont know ho do you guys attach image and directly can show in the forum window / thread
(3,671 Views)
Hi AbangCorp,
I suggest masking different colors (in your case, red, green, and blue would suffice), and performing particle analysis on the area of each color, then selecting the one with the most area.
Hope this helps!
Maclean G.
Applications Engineering
(3,644 Views)
Err, i think you misunderstood me. However i am thankful as i really need to know how to select between colours (particle analysis) and you have given me an answer. (later on can you help me on how to select colour, it may have more than the picture i showed as this depends on how many i detect to do segmentation)
What i really need is that to make vision tasks of calculating automatically which colour has the biggest area and which colour is to be selected as mask from file.
Please help me
(3,638 Views)
Hi AbangCorp,
In LabVIEW, you could create a loop that thresholds one region of color at a time, and performs the mass calculation to find which color is predominant.  In Vision Assistant however, you would have to do that task manually.  I suggest creating a threshold task in Vision Assistant that always uses green, and then when you create the LabVIEW code, add the loop to include all colors.
Hope this helps!
Maclean G.
(3,630 Views)
