Machine Vision
label OCR failure
I'm new to NI vision and currently developing a label inspection project. The objective is to verify all label printed are no defect before ship out to customer.
the step is:-
1. I've trained a image 'A' in OCR/ORV vision assistant and saved as a characther file.
2. I inspect the letter 'A' back score is 1000 (as aspected because i trained with same image)
3. I purposely Edit the letter 'A' in paint by wipe a line in the middle and save as new image, but when using OCR/OCV it still read 'A' (infact it already defect)
4. try the play with the threshold, size, read option setting still not able to get my expected result.
question:
1. how do i fail the letter defect 'A'? the score is very high as well (999) after i purposely defect it.
2. the vision assistant claim it can do OCR/OCV but i only see OCR function and it's not come with OCV function.
(5,265 Views)
Accepted by klloo
Hi Klloo
By controlling the character size you can fail defect A.
(5,225 Views)
Thank you, problems solve
(5,196 Views)
