Machine Vision
jai m30
I have a JAI camera (CV M30) and a IC-PCI card from imaging tech who are DALSA now.
I found a driver for labview on hamamatsu site, I have VIs in labview but nothing in MAX.
I have the wrong driver? or MAX is bad configured?
If you can help me, thank you.
(3,153 Views)
Hi Fred_Douille,
The Drivers you have are developed for LabVIEW and not for Measurement and Automation Explorer; this is why you cannot see your device in MAX. Basically you can interact with your PCI-board using you are in luck because NI-VISA will help you.
To use NI-VISA for PCI, just get your register description manual from the vendor and follow the instructions in this paper on our site.
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(3,111 Views)
