Machine Vision
imgsnap 64-bit windows7
Thierry,
MAX reports are in attachment. I cannot open the link on the System Information Reports. This week, I checked computer 4 (which is identical to computer 1 in hardware) and there "image on demand" works without a problem.
Bart
Message 21 of 22
(804 Views)
The link was indeed not correct.
This is the right one: http://digital.ni.com/public.nsf/allkb/DDF39729A407BFC1862578F7007807A3?OpenDocument
Some extra questions about the tests above:
- Was the same network set-up used in all the tests (network infrastructure & camera's)?
- Did you make different compiled code/executables for the 64 bit and the 32-bit environment?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 22 of 22
(786 Views)
