Machine Vision
Edge detection?
I am trying to perform edge detection to measure the distance between two edges as shown in the attached GOOD IMAGE file.
When I run the VI (Screen shot attached) it some times detects the distance between a black particle and a edge shown in the BAD IMAGE file.
Can somebody help me solve this issue?
Please let me know what kind of filtering or threshold I need to use to make the bad image look like the good image.
Thanks and regards,
Visswanathan
(3,279 Views)
A few suggestions:  Use a wide edge detection setting that is less likely to pick up small points.  Use "best edge" to find the highest contrast.  If they still have it, use a long filter in the direction of edge detection to only find thick edges, once again ignoring small particles.
Bruce
Bruce Ammons
Ammons Engineering
(3,266 Views)
