Machine Vision
imaqMatchShape - Sample Code
Could someone post some sample code using the imaqMatchShape function.  I've been unable to successfully use this feature and I'm running out of ideas.  In particular, what are the steps that need to be taken prior to making this funcitn call? Do I need to modify the borders somehow?  Thanx.
(3,922 Views)
I think you could find an example at:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E09356A4E034080020E74861
(3,914 Views)
Thank you Steffen for your help. I was actually looking for samples in C++. That was my fault,  I should have stated that in my original post.
(3,910 Views)
Here is a quick example that should work for you.  I built it using Vision Assistant and didn't spend a lot of time testing it, but it should give you a good idea of how to get started.  Let me know if you have any problems, or questions.
Arves
S. Arves S.
(3,903 Views)
Arves, thank you so much...this is exactly what I was looking for!
(3,884 Views)
