09-17-2007 07:15 PM
09-18-2007 08:04 AM
Danny,
Thanks for using the National Instruments forums. The "NI-IMAQ Devices" folder will only appear if MAX has detected a valid camera that uses the NI-IMAQ driver. The IMAQ-USB driver is completely seperate from the regular NI-IMAQ drivers, and unfortunately do not show up as folder in MAX. These drivers only allow you access to your USB cameras through LabVIEW, as they use DirectShow to access the manufactuer's configuration screens. Hope this clears things up!
