Machine Vision
how to save binary image
Hello everyone.
How to save binary image in a computer? If I right click on the image, then choose 'Save Image...', the picture saved will appear blank. I understand the image is in 0 and 1 but I do not know how to set up the code.
Thank you.
Message 1 of 10
(6,949 Views)
Right click==>Save Image
works perfect Smiley Wink
Message 2 of 10
(6,920 Views)
If I right click and save image, the image will appear black.. Smiley Sad
Message 3 of 10
(6,915 Views)
I don't know about yours, but mine works absolutely perfect Smiley Wink
Message 4 of 10
(6,913 Views)
The image is saving correctly, but like you say it looks black.  Standard viewers do not rescale the pixel intensities.
If you want a black and white image, you need to increase the value of the brighter pixels before saving.  One trick I use is multiplying the image by 255, which turns all the non-zero pixels into the brightest possible pixel.  There are probably more efficient methods, such as a lookup table, but multiplying is quick and dirty.
Bruce
Bruce Ammons
Ammons Engineering
Message 5 of 10
(6,903 Views)
Bruce is right. Here is a discussion on this:
http://forums.ni.com/t5/Machine-Vision/How-do-you-write-an-image-threshold-to-a-file/td-p/93172
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 6 of 10
(6,899 Views)
Hi Bruce.
I am not sure how to do the multiplication by 255. You mean multiply the whole program by 255 or just multiply the image?
Thanks.
Message 7 of 10
(6,883 Views)
Accepted by topic author nadiah
Use IMAQ Multiply to multiply the image times 255.
Bruce
Bruce Ammons
Ammons Engineering
Message 8 of 10
(6,873 Views)
hi can plz help me out.....i want to show grayscale images into Bitmap (0-7 bits). Is it possible to show garyscale image into bitmap 1 bit, 2bit,..upto...7bit image.
Message 9 of 10
(6,800 Views)
Message 10 of 10
(6,799 Views)
