Machine Vision
how to remove background from the image?
Hi muks,
How about this image? It is help to remove the background?
Message 11 of 30
(2,429 Views)
Hi muks,
Message 12 of 30
(2,430 Views)
The clarity has defenitely improved but the illumination is still patchy. What is the lighting that you have used? HAve you tried dome lighting?
Message 13 of 30
(2,417 Views)
yes, dome lighting..long led white lamp (almost like pendafluor lamp).
Message 14 of 30
(2,415 Views)
I amtalking about something like this
Message 15 of 30
(2,413 Views)
ic...the light not as shown in the web link...I am not sure whether we can change the light or not since it already fabricate and attached with the conveyer for end user. Maybe we have to figure out on how to tune the illumination without changing the lamp..
Message 16 of 30
(2,408 Views)
If the lighting is fixed then i suppose the maximum you can do is change the angle a bit and try to avaoid that white band that will hinder your processing. Can you also show us what are the defects that you are trying to identify?
Message 17 of 30
(2,404 Views)
The end user wants to identify the difference colour of the fruit, which can compare which one is the ripe,unripe and too ripe. I think the end user has selected the thorn of the fruit to differentiate which each other. but the identification is using other software and other algorithm. The labview (my task) is only used to detect (pixel) and save the image when the fruit at the center of the camera.
Message 18 of 30
(2,402 Views)
And are you using any through beam sensor?
Message 19 of 30
(2,400 Views)
there is no beam sensor.
Message 20 of 30
(2,399 Views)
