Machine Vision
how to get a region by mouse click
I am using C# .net. I want to use the mouse to select a region from the source image for mask. How can I get the Left, Top, Width, Height values by mouse selected on the source image.
axCWIMAQViewer.Regions.RemoveAll();
axCWIMAQViewer.Region.GetRegionData(); //????
Greetings.
Message Edited by newuser12342 on 11-10-2008 09:24 AM
(3,667 Views)
Accepted by newuser12342
Look in google and search for mouse coordinate - you find something like that
http://www.mycsharp.de/wbb2/thread.php?threadid=61761
   Private Sub Form2_MouseMove(ByVal sender As Object, ByVal e As System.Windows.Forms.MouseEventArgs) Handles Me.MouseMove
        Dim x, y As Integer
        x = Me.MousePosition.X - (Me.Location.X + 4) '+4 wegen den rändern der form
        y = Me.MousePosition.Y - (Me.Location.Y + 30) '+30 wegen der titelleiste und dem unteren rahmen
        Form1.PictureBox1.Location = New System.Drawing.Point(x, y)
    End Sub
Or use this:
Control.PointToScreen und Control.PointToClient
When i create a mouse event in my Visual Studion 2005 C# project i can work with x and y values:
private void axCWIMAQViewer1_MouseDownEvent(object sender, AxNationalInstruments.CWIMAQControls._DCWIMAQViewerEvents_MouseDownEvent e)
e.x                                        //x  coordinates
Please give me feedback if the help suggestions help you to work with mouse coordinates
(3,652 Views)
hi there,
I use  axCWIMAQViewer1_MouseDownEvent, axCWIMAQViewer1_MouseMoveEvent, axCWIMAQViewer1_MouseUpEvent to get the ROI by mouse selected.
It works fine.
Thanks for the info.
Greetings.
(3,630 Views)
