09-17-2014 11:01 AM
Dears,
I hope that anyone can help me to solve this problem...
I need to apply vertical projection on image that contain a vehicle with plate to determine the propably location of the car plate.
please find the attached 2 images 17.jpg is image which i want to apply horizontal projection, v-h[projection].png is what i want to do like it
thank...
Solved! Go to Solution.
09-17-2014 12:03 PM
Looks like IMAQ LinearAverages to me. If you multiply the averages by the number of rows or columns, you will get the count for a binary image.
Bruce
09-21-2014 05:33 AM
Thanks BruceAmmons
That solve one of my question, Sobel edge detection find all edges in the image. i want to seperate the vertical edges from horizontal edges.
Thanks ,,,,,
09-21-2014 10:00 AM - edited 09-21-2014 10:01 AM
if you want to seperate vertical and horizontal approximations of the derivatives, use linear filter (IMAQ Convolution operator), specifying two different convolution kernels - one for vertical and another for horizontal direction.
For example, see here:
http://forums.ni.com/t5/Machine-Vision/creating-double-precision-image-from-uint8/m-p/2796260#M41746
K
09-25-2014 06:19 AM
Thanks Klemen
Im trying to find way to extract car plate from image
i use gaussian -> Sobel -> detect rectangle but accuracy not good
i use gaussian -> match pattern but the pattern not available in all images
i use sobel -> binary -> vertical/ horizontal projection not all edges detected
please if you can share with me some techniques it will be good for me
