Machine Vision
how to apply vertical and horizontal projection?
Dears,
I hope that anyone can help me to solve this problem...
I need to apply vertical projection on image that contain a vehicle with plate to determine the propably location of the car plate.
please find the attached 2 images 17.jpg is image which i want to apply horizontal projection, v-h[projection].png is what i want to do like it
thank...
(5,825 Views)
Accepted by topic author GeniusIDS
Looks like IMAQ LinearAverages to me.  If you multiply the averages by the number of rows or columns, you will get the count for a binary image.
Bruce
Bruce Ammons
Ammons Engineering
(5,820 Views)
That solve one of my question, Sobel edge detection find all edges in the image. i want to seperate the vertical edges from horizontal edges.
Thanks ,,,,,
(5,756 Views)
if you want to seperate vertical and horizontal approximations of the derivatives, use linear filter (IMAQ Convolution operator), specifying two different convolution kernels - one for vertical and another for horizontal direction.
For example, see here:
http://forums.ni.com/t5/Machine-Vision/creating-double-precision-image-from-uint8/m-p/2796260#M41746
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,747 Views)
Thanks Klemen
Im trying to find way to extract car plate from image
i use gaussian -> Sobel -> detect rectangle but accuracy not good
i use gaussian -> match pattern but the pattern not available in all images
i use sobel -> binary -> vertical/ horizontal projection not all edges detected
please if  you can share with me some techniques it will be good for me
(5,709 Views)
