how can use the MAX
vsa
how can use the MAX
Hello
I work with LabVIEW 2012,
after I inestalled may camera, I could not use MAX and my camera was not appear in MAX, how can I see my camera in MAX?
6 REPLIES 6
Highlighted
Silver_Shaper
Re: how can use the MAX
Which camera are you using? Did you install the vision acqusition driver?
Silver_Shaper | CLD
vsa
I use Apogee camera (Alta Series)
I did not install that driver.
Silver_Shaper
Oh . Install the driver. Then it can be accessible.
Silver_Shaper | CLD
vsa
ok, thanks
vsa
I install that but it does not appear!!!
Silver_Shaper
What kind of interface it has? USB/FireWire/GigE
Silver_Shaper | CLD
