 Shimonek
			Shimonek
			12-06-2005 12:59 PM
I’m having trouble with my NI-1409 analog frame grabber. The image has a single bright (or many depending on the image) white horizontal streak across the entire image. It starts where there is a hard contrast change on the left side. Any ideas would be appreciated.
Thank you,
 BruceAmmons
			BruceAmmons
			12-06-2005 01:14 PM
Sounds something like blooming. That would be an issue with the CCD of your camera, not the framegrabber.
Do the streaks go away when you reduce the gain or aperture or shutter time on the camera?
What camera are you using?
Bruce
12-06-2005 02:09 PM
It’s not the camera. On an EPIX frame grabber and a standard monitor it doesn’t have this problem.
Thanx,
 AnalogKid2Digit
			AnalogKid2Digit12-06-2005 02:35 PM
12-06-2005 03:16 PM
Fixed... I looked at my camera parameters and it looks like I was setting my black level within the image (the far left pixels)
Thank you,
