Machine Vision
graph shape matching
hi . ..
i have ploted graph.. i want to compare the graph shape with another graph...
so i convert the plot to picture and then to image which imaq can process.. which kind of matching shoulld i use to match graphs. i dont think pattern matching really suits the matching.. which vi does geometric matching to match the shapes of the graph? .. can anyone help me ?? thanks
Message Edited by kupikupi on 09-20-2006 01:45 AM
(3,749 Views)
I am not clear as to what you are trying to do.  Are you trying to find the location of a certain pattern in two graphs? There is a IMAQ Match Geometric Pattern.vi.
Christopher W.
(3,731 Views)
thanks chris,
    i just found the VI .. in another comp .. is there any where i can learn how to use the setup and matching .. all the settings.. ?
thanks
(3,729 Views)
This just sounds like a crazy way to compare two graphs.  If you have the data for the original graphs, why go to all the trouble of trying to compare the graphs?
Can you post a graph so we can see what you are trying to compare?
Bruce
Bruce Ammons
Ammons Engineering
(3,726 Views)
