Machine Vision
explaination of the function imgCreateBuffer
Can someone explain the function imgCreateBuffer to me.  How does this function set the buffer size?
Torrence
(3,402 Views)
Hello Torrence,
The imgCreateBuffer function creates a buffer of image space that you can then be set into the Buffer List.  There is a parameter for imgCreateBuffer called "uInt32 bufferSize" that you can use to set the size of your buffer.  The buffer size needs to be atleast = [ROI height] x [rowPixels] x [number of bytes per pixel].  This basically allocates memory so images can use DMA to transfer directly into kernal level memory.  You can find out the description for the IMAQ function calls by going to: Program Files >> National Instruments >> Vision >> Documentation and then choosing "NI IMAQ Function Reference".  We also have examples that are shipped with NI IMAQ that can be found by opening up a windows explorer menu and going to the following destination: "<root>:\Program Files\National Instruments\NI-IMAQ\Sample".  In here a good example to look at that uses imgCreateBuffer is "LL Ring".  I hope this information helps.  Thanks and have a great day.
Mark T
(3,392 Views)
Thank You. This does help me.
Torrence
(3,383 Views)
