03-10-2007
07:46 AM
- last edited on
07-08-2025
04:08 PM
by
Content Cleaner
03-10-2007 12:44 PM
03-11-2007
11:19 PM
- last edited on
07-08-2025
04:09 PM
by
Content Cleaner
Hey 2and4,
I remember that some others were also having some other errors similar to yours with other functions with an older version of the NI-IMAQ driver software and the Really Old 1408. I know that all of those issues were fixed in the most recent version of the NI-IMAQ software (which comes with the NI Vision Acquisition Software). You can download and install this newer version of the software at the following link: https://www.ni.com/en/support/downloads/drivers/download.vision-acquisition-software.html.
This is actually a better resolution than replacing that file that you found. This fixes not only your original issue, but also any other issues you might see by using the older version of the IMAQ driver. I hope this helps and makes sense. Please let me know if you have any further questions or concerns. Thanks, and have a great day.
DJ L.
03-12-2007 12:13 AM
DJ L., Thanks for your help. Are you sure that that issue was resolved in the latest version of NI-IMAQ? I had actually downloaded the latest version to begin with (evaluation mode) and I ran into that error and thought it could be because I did use the latest version while using LabVIEW 8 instead of 8.2. Then I uninstalled those latest copies and downloaded older versions and got the same results (meaning the same error). The problem got resolved once I replaced that one VI. My guess is I would have to do that with the latest version of IMAQ too.
If I run into any other errors I'll download the latest version of IMAQ.
03-12-2007 07:57 AM
03-12-2007 08:53 AM
03-12-2007 09:39 AM
03-13-2007 02:26 PM
03-13-2007 03:37 PM
03-13-2007 03:41 PM
