Machine Vision
error
whenever i try to run the program for inspectioning the image acquired by VBAI i am only destined to get an error as inn the below image. Sometimes i prompt to the message that "the session you are using is no longer valid". What to do to take away these errors from vi? The relevant error code is -354713.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(4,120 Views)
Make sure you connect an image that was created by the IMAQ Create Image vi. See the shipping example we have for how to use the VBAI API in labview. It's located in the VBAI folder under API examples.
Hope that helps
Brad
(4,113 Views)
Thank you. Hope this wil be my solution.:)
Best Regards,
Dhans 😉
Kudos are welcome 😉
(4,113 Views)
