Machine Vision
dual GigE card
I need to use 2 gigE cameras on a system and am looking for a dual port card, is there a prefered one to work with windows 7 and imaqDX drivers to communicate with 2 gige cameras.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,452 Views)
Accepted by falkpl
At AVT/Prosilica we recommend the Intel Pro/1000 PT Dual Port card.
... works well with both:
(a) two separate GigE Vision cameras, and also with
(b) 2-port LAG (Link Aggregate Group) cameras like the GX series
Scott
(4,450 Views)
thanks,
is this the same as 2-port pro/1000 pt pci express server adapter.  does this work with windows 7 and possibly 64 bits?
Paul Falkenstein
(4,444 Views)
(4,441 Views)
That above card should likely work with NI's High Performance Driver (and of course 64-bits and Windows 7), assuming it is of a similar revision that we have qualified support for. For guaranteed support, you could also go with NI's PCIe-1435, which is bundled with Vision Acquisition Software and you can get direct support for the hardware from NI.
Eric
(4,438 Views)
I use the same NIC with Windows 7 64 Bit (and LV 2009 64Bit) and it works fine with 2 GigE cameras.
(4,415 Views)
thanks for all the help I will give this a try.
Paul Falkenstein
(4,397 Views)
