03-25-2010 08:49 AM
Dear all,
I am a new user of labview and vision assistant.
I need to acquire the flying shape of sails.
This means that I will have a certain number of markers on the sail. Using vision assistant I would be able to get their coordinates.
If I use the Particle Analysis I am not able to classify the markers and consequently the particle order is random.
If I use Machine Vision I can detect the objects using Pattern Matching but I encounter 2 main problems:
1.the accurancy of the pattern centre
2.if the sail rotates in a 3D plane It is not able to match the pattern.
Do you have any suggestion?
Laura
03-26-2010 12:10 AM
03-26-2010 04:47 AM
03-26-2010 06:25 AM
