12-17-2007 01:59 PM
12-18-2007 09:10 PM
Hi Steve,
The result of the threshold operation is a binary image, cant this result itself be used as a mask for the original?
Jaidev
12-19-2007 01:08 PM
It could be but the image itself has a border around it that would throw off edge detection for the inner particle analysis.
At this point in time I am working with ideas of seperate, premade masks that are cumbersome in memory and slow down the process.
Another option I am working with is manually drawing using the polygon tool a certain, small distance from the actual edges which proves to be time consuming but very light in terms of memory use.
Any other ideas or suggestions are greatly appreciated.
12-20-2007 10:08 AM
