Machine Vision
deep learning
How can I open the .pb file which is used in the deep learning example to make some changes .??
(2,780 Views)
You can use TensorBoard’s Graphs dashboard to explore the graph.
(Examining the TensorFlow Graph)
But I would like to recommend to install Python and TensorFlow, then create your own (its not so easy if you will do this first time).
Here is good starting point:
Tensorflow API for LabVIEW
Andrey.
(2,701 Views)
Thanks for your help
(2,693 Views)
