Machine Vision
IMAQdx Get Image 2 Timeout
The issue I am having is that I am able to get a continuous acquisition without a timeout using NI MAX, but when I try to implement a simple grab vi, it times out every time at around 5 seconds into the acquisition.  The particular error is Error -1074360293 occurred at IMAQdx Get Image2.vi.
 I am not sure if it is something I'm doing wrong, a driver issue or something else.  It is a 4K GIGE Camera (Sentech STC-SBS500POE), so it would make sense if it drops frames once in a while, but what really confuses me is that it works fine in NI MAX but not in my VI.
(2,484 Views)
I forgot to mention that I have also changed the default timeout in the Grab VI and the Get Image VI to something like 10 seconds with it timing out at 5 seconds into the acquisition.
(2,445 Views)
