01-17-2007 08:49 AM
01-21-2007
09:44 PM
- last edited on
10-27-2025
04:27 PM
by
Content Cleaner
Hello Serge,
Thank you for using National Instruments discussion forums. To log data on the CVS using VBAI you can consult the help documentation that is shipped with VBAI 3.0. Look at Vision Builder AI Configuration Interface Help and Navigate to: "Creating Steps for an Inspection >> Additional Tools >> Data Logging" for information on how to do this with VBAI. You can also choose to log the data to an FTP server if you have one setup. You can then setup Data Socket on the CVS to tranfer data to a host computer. DataSocket can be found under the Communicate section of the inspection steps. When you do this you need to specify an IP address as well as a port number. On the host computer at that IP address you will have to create a program that will listen on that port to receive the data. For more information on how to use Data Socket on the host computer check out the links below. I hope this helps. Thanks and have a great day.
DataSocket Overview
Mark T
Applications Engineer
01-26-2007 10:23 AM
01-26-2007 10:26 AM
hello Mark i got another question,
Could you please watch my question on the forum named : What's wrong with thie VI?
Serge
01-29-2007 09:27 PM
01-30-2007
09:21 AM
- last edited on
10-27-2025
04:28 PM
by
Content Cleaner
This thread?
https://forums.ni.com/t5/LabVIEW/What-s-wrong-with-this-Vi/m-p/469376#M226288
