Machine Vision
conversion from 2013 to 2011
original.pngHi,
    can you the attached file from 2013 to 2011 version.
Thank you
(4,132 Views)
this is a snapshot and it cannot be converted. But the vi's used are present in Labview 2011 also, so you can apply them yourself.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,120 Views)
when you attach the VI I save it in version 2011 for you.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(4,094 Views)
