Machine Vision
cell boundary detection
many years ago, around 2002,  i downloaded an example file called "culture.zip", which contained culture.vi.
Culture.vi allowed the boundary of a cell(s) to be acquired from a still image.
I still have the orignal culture zip file which came from NI,  but it dosent appear to run under labivew 8.5
When i open this file, there are a few broken lines which prevent its execution.
I would like to find an updated version of this file.
I have searched and found the same images that were in culture.vi posted online.
http://volt.ni.com/niwc/imaq/appcount.jsp
Anyone know where a working copy of the example file are?
Or even better, a more updated version of a routine to find cell boundaries?
thanks
(4,696 Views)
This is a shipping example, according to Chilly Charly. (http://forums.ni.com/ni/board/message?board.id=200&requireLogin=False&thread.id=6060)
In Vision Assistant, use Help > Solution Wizard > Culture Analysis.
Bruce
Message Edited by Bruce Ammons on 12-24-2008 11:18 PM
Bruce Ammons
Ammons Engineering
(4,690 Views)
Hi Bruce.
Thats not really the same file.
It does a similar function though.
Its a vision script or .scr file.
There is a VI in the directory but i it cant be opened.
If I posted the orignal file, can someone take a look?
(4,681 Views)
here is the orignal file i downloaded about 6 to 7 years ago.
www.engr.uconn.edu/~jmacione/temp/culture.zip
Id like to get a working example for a newbie to get started in labview.
(4,680 Views)
Accepted by jimmyinCT
jimmyinCT a écrit:
Hi Bruce.
Thats not really the same file. It does a similar function though.
Its a vision script or .scr file. There is a VI in the directory but i it cant be opened.
Since you can run IMAQ vision VIs, you also have access to Vision Assistant. So you can open .scr files... and of course you can build automatically the corresponding VI ! Give it a try.
Chilly Charly    (aka CC)
(4,669 Views)
so tools menu and there is an option to build vi
ok, ill give this a try.
thanks
(4,661 Views)
