Machine Vision
取消
显示结果
搜索替代
您的意思是:
can't find IMAQ cast image vi
I'm trying to write an avi file from an array of images. I get the message that it's an invalid image. I see elsewhere that I need to cast the image from a 10-bit to an 8-bit image, but I can't find the cast image vi anywhere under vi.lib/vision.  Where is it?
0 项奖励
1 条消息(共 10 条)
9,327 次查看
I am thinking it is only available with the Vision toolkit.  If you don't have the Vision toolkit, that might explain it.
My other thought is that I have seen that group of VIs disappear during installation of IMAQ drivers.  You might need to repair your Vision installation to get it to reappear.
Bruce
Bruce Ammons
Ammons Engineering
0 项奖励
2 条消息(共 10 条)
9,321 次查看
Well, I have Vision 7.1.1.  Is this the same as the toolkit or is that something separate? I seem to have vis for making avi files and reading images from cameras, so I would think that I should have a vi for casting an image to another format. I will try reinstalling the Vision CDs.
0 项奖励
3 条消息(共 10 条)
9,314 次查看
Since you have Vision 7.1.1 the IMAQ Cast Image VI will be located in the Vision Utilities >> Image Management Palette in LabVIEW if everything is right on the system.  It is possible that there was a problem with the installer as Bruce noted above.  In this case, a reinstallation or repair of Vision should fix the problem.   Another source of the dissappearence could be if you are using LabVIEW 8. Vision 7.1.1 will not natively work with LabVIEW 8, but there is a utility available to port it over.
Vision Utility
How Do I Install My IMAQ Vision Software and Drivers With LabVIEW 8?
http://digital.ni.com/public.nsf/websearch/25FD880AC87C4DA6862570B30056C572?OpenDocument
For NI-IMAQ 3.1.1 the VIs in this Knowledge Base
Which non-driver VIs are installed with NI-IMAQ?
http://digital.ni.com/public.nsf/websearch/392E8F10F049918986256A3B005D484A?OpenDocument
For the Vision Acquisition Software (NI-IMAQ 3.5.1) the installed VIs are listed in this KB
VIs Included With the NI-IMAQ Driver/Vision Acquisition Software
http://digital.ni.com/public.nsf/websearch/86256F0E001DA9FD86256EA200507080?OpenDocument
S. Arves S.
Applications Engineer
0 项奖励
4 条消息(共 10 条)
9,296 次查看
OK I recently received the Vision 8.0 update and just now installed it. Now I can see many things on the vision pallette that were not there before, including the Cast Image vi. It looks like it's going to be a whole lot easier to program now.
Steve
0 项奖励
5 条消息(共 10 条)
9,292 次查看
Happy to hear it's working.  I completely agree with you that it is much easier to program with Vision 8.
S. Arves S.
0 项奖励
6 条消息(共 10 条)
9,287 次查看
I reinstalled the Vision 8.5 (including IMAQ 3.8, IMAQdx 3.1 and IMAQ I/O 2.1) but still couldn't find the IMAQ Cast Image.vi.
Does anyone know where to download the vi?
Please help.
Jun
0 项奖励
7 条消息(共 10 条)
8,918 次查看
Hi Jun,
Are you using the search on the function pallate to look for the cast image VI? What version of LabVIEW do you have?
Can you open your command prompt (Start » Run... then type in cmd and click OK) and navigate to your LabVIEW folder? On my computer, I can get there by typing in:
cd /D C:
    <Enter>
cd Program Files\National Instruments\LabVIEW 8.5\
   <Enter>
Then go to the vision folder in the vi.lib folder:
cd vi.lib\vision
   <Enter>
Now, we are in the folder in which all the Vision files reside. Then, you can type:
dir /S /N > C:\visionfolder.txt
   <Enter>
What this will do is list all of the contents of the Vision folder and all its subfolders, and put it into a text file named visionfolder.txt in your C: drive. If you open up your Local disk C drive (or wherever you put that visionfolder.txt file), you will see the text file there filled with the directory structure of your vision folder. Please attach that file to the forums so we can look at what files you have installed.
Thank you kindly,
Maclean G.
Applications Engineering
0 项奖励
8 条消息(共 10 条)
8,905 次查看
Hi Maclean G.,
Thank you for the advice. I have attached the visionfolder.txt in which I still don't see the cast image.vi.
Please look at the file and advise.
Jun
0 项奖励
9 条消息(共 10 条)
8,891 次查看
Hi Jun,
It looks like you have the Vision Acquisition Software installed, but not the Vision Development Module. You need the latter to have the IMAQ cast VI. You can follow that second link to download and install an evaluation version of the VDM, and then you will see the cast VI on your function palette.
Maclean G.
0 项奖励
10 条消息(共 10 条)
8,863 次查看
